a/c not cooling
have a 95 f22b1
as of late in the warmer weather, a/c just is not cooling enough to keep it cool. i bought a recharge kit, but the gauge shows the system is full. is there a way to drain and recharge? could that be the prob? it defogs perfectly, just doesnt keep up with the heat. |
You may want to pull back the radiator and lightly spray the a/c condenser with water to remove any dirt buildup.
The only way to know how your a/c is performing is to do a pressure test on the high and low pressure side using an a/c manifold. You can also observe the clutch plate to see if it keeps spinning with the a/c pulley while the engine is running. |
I'm gonna have to take it to a shop.. Hoping it would be a easy answer or fix
Check the blend door, adjust to be sure it (and the heater control valve) are closing all the way....I check/adjust mine, 10 min tops, about every spring.
