a/c not cooling
Old May 20, 2011 | 12:35 AM
Tek310's Avatar
Default a/c not cooling
have a 95 f22b1
as of late in the warmer weather, a/c just is not cooling enough to keep it cool.
i bought a recharge kit, but the gauge shows the system is full.
is there a way to drain and recharge? could that be the prob? it defogs perfectly, just doesnt keep up with the heat.
Old May 20, 2011 | 12:58 AM
You may want to pull back the radiator and lightly spray the a/c condenser with water to remove any dirt buildup.
The only way to know how your a/c is performing is to do a pressure test on the high and low pressure side using an a/c manifold.
You can also observe the clutch plate to see if it keeps spinning with the a/c pulley while the engine is running.
Old May 20, 2011 | 01:51 AM
Tek310's Avatar
I'm gonna have to take it to a shop.. Hoping it would be a easy answer or fix
Old May 20, 2011 | 06:34 PM
Check the blend door, adjust to be sure it (and the heater control valve) are closing all the way....I check/adjust mine, 10 min tops, about every spring.
rolling
Jul 26, 2012 09:48 AM
Plumcrazebody
Nov 16, 2010 08:48 PM
SteveZ
Jan 5, 2008 05:08 PM
adamc44
May 23, 2007 08:57 PM
blazedg
Jul 7, 2005 05:03 AM
