a/c not cooling
Old May 23, 2007 | 04:14 PM
adamc44's Avatar
Default a/c not cooling
i have a 94 lx. i went to use the air conditioner and the pump kicks in, and it blew semi cool air. well i figured it needs recharged. took it to get recharged and picked it up about quitting time for the mechanic. i drove it home and it isnt any cooler than before. soeither they guy didnt recharge it or somthing else isscrewed up. any leads on what to look for so i can diagnose the problem. thanks
Old May 23, 2007 | 08:57 PM
Default RE: a/c not cooling
Perhaps a failing expansion valve, very dirty condensor blocking cooling air flow, or partially blocked evaporator.
A diagnosis requires measuring system hi/lo pressures w/ a manifold gauge set to determine whether compressor is actually compressing, expansion valve is metering refrigerant, or other problem.
rolling
Jul 26, 2012 09:48 AM
jhuck
Mar 28, 2011 11:30 PM
Plumcrazebody
Nov 16, 2010 08:48 PM
SteveZ
Jan 5, 2008 05:08 PM
blazedg
Jul 7, 2005 05:03 AM
