hunts when hot
Old May 23, 2007 | 03:50 PM
nickbt
Default hunts when hot
when engine gets hot revs seem to wander up and down.i have been told it may be the lamba sensor.is this plausible or any other reason?
Old May 23, 2007 | 09:01 PM
Default RE: hunts when hot
Idle air control valve (IACV) is much more likely. Remove IACV and clean inlet screen and valve movement thoroughly. Clean throttle body bore and plate from entrance w/ old toothbrush and throttle body cleaner. Check that PCV is clean and and PCV hose is open.
Is Check Engine Light on? If yes, obtain codes and post them for help.
Dan50
Feb 5, 2009 07:30 PM
nickbt
May 23, 2007 11:29 PM
soldierforchrist2
Dec 4, 2005 11:34 PM
jordan
Sep 6, 2005 11:35 PM
Moder
May 28, 2005 09:29 AM
