A/C not working
Old Feb 13, 2008 | 02:51 PM
will93's Avatar
Default A/C not working
Hi all. 93 accord lx. I have no idea where togo beyond fuses. This car is pretty new to me (2mo) and I thought I tested the A/C. Well I guess I did turn it on when I was testdriving the car and it was ~40 outside, it was cold...'duh.
We had 65 degrees the other day and I tried the air. No cool. All fuses labeled A/C looked fine.Tempseemed as if its only vent air. I also feel no noticable pull on the engine when I turned it on as I'd expect.
Please give me some logical first steps and pretend Im a 5yo. I need basics.
Thanks for any assistance.
Old Feb 13, 2008 | 03:09 PM
klrspz's Avatar
Default RE: A/C not working
Feel along the condenser line off the ac compressor.. is it cold and have condensation? If it's warm, chances are it's in need of a charge.
my $0.02
Old Feb 13, 2008 | 03:53 PM
hondafix's Avatar
I not sure, however maybe 65 degrees still might be too cool to test A/C. I'm sure someone here can better anwser this for you.
I myself about two years ago had trouble with my A/C, in the summer I when turned on the A/C there was only warm air. I took car to the dealer and was told that I needed a new compressor. I passed on the repairs, and drove car the rest of summer without A/C.
The next season, I took car to Sears for new tires and mentioned my A/C trouble. I was surprised when they told me it was only the A/C temp. control **** inside car. Seems like the inside of **** was cracked, so when I was turning **** it was not turning the stem of A/C temp control.
So the first thing I would do is pull off **** and make sure it is not cracked. I was told that they tend to crack often, and they are very inexpensive at the Honda dealer. I used a needle nose plier to turn stem until I had a chance to get a new ****.
Hope your problem is just as simple, good luck!
Old Feb 13, 2008 | 04:15 PM
Definitely check the a/c control **** that hondafix mentioned.
You should check to see if the a/c clutch is engaging. Basically start your car up, and have someone turn on the A/C when its running. If you look at the outer edge of the compressor pulley, the plate (clutch) should not spin when the A/C is off. It should spin at the same rate with the pulley when the A/C is on.
Also check that both of the cooling fans turn on when the a/c is turned on.
Let us know what you find.
Old Feb 13, 2008 | 07:49 PM
jcocker03's Avatar
I have a 92 accord lx, and the AC doesn't work. The people i bought it from had the compressor replaced twice, and twice the compressor died after about 30,000 miles. The mechanic told them it was the location of the compressor, said it was getting hit by rocks, stones, and other debris kicked up while driving.
Old Feb 15, 2008 | 09:45 AM
will93's Avatar
ORIGINAL: PAhonda
Pulled the **** last night and unfortunately that is not the problem. Its in good shape and turning the stem. Will followup again upon next inspection.
Thanks.
Old Feb 15, 2008 | 07:03 PM
ORIGINAL: jcocker03
Best to start your own thread.
BS from the mechanic about rocks and debris damaging compressor. Rocks can damage the condensor, but not the compressor.
If you have a question it helps to state the question for best response. Don't make us guess.
Gangsta101
Feb 10, 2013 01:50 AM
LaGirl
Apr 24, 2012 05:29 PM
MoDawG
Dec 10, 2009 07:00 AM
sthavorn
Apr 7, 2007 10:12 PM
arunsam3000
Mar 6, 2007 01:40 PM
