a/c problem (DISABLED VET)
I hope somebody can help me. I have 2003 3.0liter v6 accord. The dealership replaced my ac compresser(NAPA) 4 months ago.BUT the didn't replace the DRYER. Now the ac system works sometimes and then it doesn't. I hear the ac compresser click on and off. And the heat works fine. The driver is warmer then the passinger side most of the time. I did have it checked for leaks. And it was okay... PLEASE HELP A Veteran. Thanks.... |
If cooling is missing when compressor is not engaged, a weak compressor clutch coil or excess clutch plate gap is likely. An intermittent AC compressor relay will cause similar symptoms.
Start by determining if no cooling occurs w/ compressor disabled (inner clutch plate not rotating). good luck |
