a/c problem (DISABLED VET)
Old Jun 22, 2016 | 11:52 AM
hondaddd's Avatar
Default a/c problem (DISABLED VET)
I hope somebody can help me. I have 2003 3.0liter v6 accord. The dealership replaced my ac compresser(NAPA) 4 months ago.BUT the didn't replace the DRYER.
Now the ac system works sometimes and then it doesn't. I hear the ac compresser click on and off. And the heat works fine. The driver is warmer then the passinger side most of the time. I did have it checked for leaks. And it was okay...
PLEASE HELP A Veteran. Thanks....
Old Jun 22, 2016 | 01:10 PM
If cooling is missing when compressor is not engaged, a weak compressor clutch coil or excess clutch plate gap is likely. An intermittent AC compressor relay will cause similar symptoms.
Start by determining if no cooling occurs w/ compressor disabled (inner clutch plate not rotating).
apmech
Sep 18, 2016 04:21 PM
kellysa111
May 1, 2009 08:35 AM
mahones
Oct 13, 2008 08:24 AM
BRIVOLBN7Q
Feb 22, 2007 01:37 AM
92Inspire
Aug 13, 2006 03:37 PM
