Caliper bolts
Old Sep 2, 2008 | 03:33 PM
jerrym's Avatar
Almost A Senior Member
Default Caliper bolts
Just replaced the rotors, brake pads, calipers, and caliper bolts on my 97 Accord.
When removing the old calipers, the bolts are a little different. One bolt is a little longer with a taper on the end and the other is just straight threads and slightly shorter.
The problem is one side of the car had the longer bolt with the taper in the top of the caliper, and the other side had the short bolt in the top of the caliper.
I am thinkingsomewhere a long the line thecaliper boltsmust have not been put in correctly on both sides. I want to make sure both sides are installed right. Does it matter which bolt goes where, and if so does the longer bolt go in the top or bottom caliper bolt hole.
Thanks for your help.
Old Sep 2, 2008 | 04:29 PM
brayner's Avatar
Default RE: Caliper bolts
are both bolts long enough? do they have the same markings on the bolt head? if so, I wouldn't worry too much about that.
Old Sep 2, 2008 | 04:37 PM
There are two different caliper bolts.
The one with the taper goes in the top hole (it should also have a little rubber sleeve towards the bottom of it). The bolt that has the flat end goes in the bottom.
Reggi's-accord
Jan 31, 2011 12:53 PM
jdmjnky
Oct 20, 2007 12:48 PM
wardykid23
Oct 9, 2007 11:48 AM
rodmathews
Aug 5, 2007 10:49 PM
val
Oct 30, 2006 03:12 AM
