Cam position sensor
Old Jun 25, 2011 | 03:29 PM
07AccordCp's Avatar
Default Cam position sensor
I have a cel on a 05 accord coupe. The code is P0369 cam position sensor B. There are 2 sensors, Intake and exhaust and im not sure which one exactly needs to be replaced. I purchased both sensors just incase.
I have 2 part numbers and the sensors are mounted side by side.
1) 37510-PNB-003
2) 37510-RAA-A01
Old Jun 25, 2011 | 05:24 PM
You didn't state whether this is for a 4 cylinder or 6.
I assume this is a 4 cylinder. Cam sensor B would be the exhaust for the 4 cylinder, so part number 37510-PNB-003.
Old Jun 25, 2011 | 07:17 PM
07AccordCp's Avatar
It's a 4 cylinder, thanks
Old Jun 26, 2011 | 12:20 PM
07AccordCp's Avatar
So I just replaced the cps after I disconnected the negative battery terminal. It took me a while to replace the sensor, well over 20 minutes. After I was done I reconnected the battery terminal and attempted to start the car, It wont start. It wont turn over and what makes it worse, the cel wont even turn on nor does the battery light. Every other light that supposed to work when the key is in on position seems to work. What could it be????
Old Jun 26, 2011 | 12:55 PM
Double check the gound cable......
Old Jun 26, 2011 | 12:58 PM
07AccordCp's Avatar
could it be the alternator or a bad ground? Here are the lights that come on when key is turned to position 2; oil light, srs, seatbelt (if unlocked), key, door (if open)
Old Jun 26, 2011 | 02:19 PM
Re-check the battery connection and other work done. If that is okay, it may just be a blown fuse in the under-hood fuse/relay box.
Old Jun 26, 2011 | 02:40 PM
When checking the fuses, focus on these:
Attached Thumbnails Cam position sensor-checking-large-fuse.jpg   Cam position sensor-underhood-fuse.jpg
Old Jun 26, 2011 | 03:08 PM
07AccordCp's Avatar
Just checked the fuses, looks fine
Old Jun 26, 2011 | 03:52 PM
Do you have a multimeter or voltmeter to check the car battery?
Also, make sure the car is in Park or Neutral and then try starting it.
