Camber kit help.
I have a 94 accord lx that i need to install camber kits on. Im not exactly sure what i need though, i have been doing some research and have found 3 types if camber kits. Im trying to find out which ones i need. This is one if the types of camber kit i found. I can't seem to figure out how to put more than one pic here.
Those Megan racing camber kits you posted a photo of are junk. I would never trust Megan with a suspension component on my car.
For the front, I always recommend Ingalls adjustable anchor bolts. You need two (two bolts for each side).
http://www.summitracing.com/parts/ie...a/model/accord
And for the rear, I would go with SPC adjustable arms. You again need two. These are one of the few adjustable rear arms that are bent like the OEM upper arm, which gives them a superior desgn. Most aftermarted arms are straight and can bend because when the suspension compresses, it makes contact with the rear spindle.
http://www.summitracing.com/parts/sp...a/model/accord
thunder_x
May 17, 2006 08:26 PM
19accord95
Feb 11, 2006 02:06 AM
