if my coil-overs have built in camber adjusters, then i wont need camber kits, right?
Old May 15, 2006 | 01:47 AM
thunder_x's Avatar
Default if my coil-overs have built in camber adjusters, then i wont need camber kits, right?
are they the same thing?
Old May 15, 2006 | 10:45 AM
stevephy's Avatar
Default RE: if my coil-overs have built in camber adjusters, then i wont need camber kits, right?
I would assume you wouldn't need anything else, if it adjusts itself, or has a mechanism that can correct -/+ camber.
What's the manufacturer?
StevePhy
Old May 15, 2006 | 07:14 PM
thunder_x's Avatar
ground control
Old May 15, 2006 | 07:30 PM
sir_nasty's Avatar
do you have a link to the product you are looking at? If it does indeed include camber adjustment that would be interesting...
Old May 15, 2006 | 09:55 PM
thunder_x's Avatar
i havent found any coil-overs with built in camber adjusters yet, but if you guys got any good sites, please tell me
i just found out about the camber adjusters from this site:
http://www.andysautosport.com/learni...coilovers.html
Old May 17, 2006 | 08:26 PM
marbro's Avatar
generally shock assymblys will have the ability to adjust camber on top of the strut , Tein's are set up that way. But if you can find full struts with built in camber adjustment, youre good as gold, as a side note, gold is about $700 an ounce ^_^
dbeltran315
Nov 26, 2011 08:37 AM
thunder_x
Oct 30, 2006 09:34 PM
19accord95
Feb 11, 2006 02:06 AM
