can someone help me
Old Oct 9, 2008 | 04:07 PM
jamrock's Avatar
Default can someone help me
I have a 94 accord ex and i jus put an new head on it . finished every thing and it started an ran for about 0 and shut off now it wont start and there is no spark now. any suggestions ????
Old Oct 9, 2008 | 04:19 PM
brayner's Avatar
Default RE: can someone help me
unplugged crankshaft sensor??
Old Oct 9, 2008 | 06:19 PM
jamrock's Avatar
does an one have the wiring diagram for the distributor
Old Oct 9, 2008 | 10:27 PM
Online manuals thread in DIY section has a link to sites with a 94 shop manual in pdf form. That will have all of the wiring information in the distributor.
Old Oct 10, 2008 | 04:01 PM
jamrock's Avatar
unplugged the cps nothing happened
Old Oct 10, 2008 | 06:40 PM
Is the Check Engine Light (CEL) on? If yes, then download codes. Diy section has procedure.
W/ no spark check the blk/yel wire at the distributor connector for voltage. No voltage would suggest an ignition switch problem. If you have voltage, either ignitor or coil is the problem. Check DIY section for procedure to determine which.
Is engine turning over? You don't say but since it started once, I assume yes.
Are you sure you re-installed timing belt correctly? If you mistimed the engine and pistons hit valves, you'll have to pull the head again.
Old Oct 10, 2008 | 08:52 PM
jamrock's Avatar
it started and ran for about 30. it cranks but there's no spark there is voltage and ground did the igniter test and found out that the igniter was bad, well im not sure if its the igniter or the coil so im goin to replace the distributor
illomatic
Mar 24, 2007 07:39 PM
thunder_x
Dec 29, 2006 01:45 AM
Sparco_racingVTEC
Jul 26, 2006 09:11 PM
98Accord220HP
Jul 23, 2006 05:29 PM
