Canastoga Wagon squeeky wagon
Old May 8, 2014 | 10:02 AM
daver1100's Avatar
Default Canastoga Wagon squeeky wagon
Hi folks- 97 Accord wagon 130k, Acquired it last December. I haven't poked around yet, maybe this weekend. This thing squeeks like a Canastoga Wagon! slow speed-squeeks like crazy. I'm embarrassed to pull into WalMart! Ha!
I need to put a right side axle in soon (click! click! click! when I turn), while I'm under there I thought I'd soak the rubber parts with a spray lubricant. Any suggestions on rubber parts needing replacement? Thanks, Dave
Old May 8, 2014 | 12:53 PM
Roader's Avatar
The usual culprits are the sway bar bushings. If they're still intact then spray silicone will provide a temporary fix. Silicone grease, available cheap at Lowe's or Home Depot as "faucet grease", will last a long time but requires a bit of disassembly.
Old May 8, 2014 | 02:41 PM
daver1100's Avatar
Default sway bar
Roader- well I did a search on replacing those sway bar bushings- looks pretty simple, might as well spend a small amount of green and just replace them. I think I'm going to have the passenger side axle out anyway... Thanks, D
banastasio
Jul 23, 2011 08:49 PM
mars28
Nov 27, 2010 01:33 PM
Stoenr
Mar 18, 2008 09:56 PM
MarkLex
Oct 21, 2007 11:13 PM
thunder_x
Apr 26, 2006 03:48 AM
