Car Overheating When Idle
Old Sep 29, 2006 | 11:44 PM
PIGGEBANK's Avatar
Default Car Overheating When Idle
When Idle, my heat guage goes to almost full and I have to get up to pretty good speed for the air to cool it down, then as soon as i slow down or stop it goes back up, I've made sure the radiator is full. Please help.
Old Sep 30, 2006 | 12:16 AM
drummer1279's Avatar
Default RE: Car Overheating When Idle
there are a couple things it could be, clogged radiator, bad water pump, or your cooling fans arent engaging when the car is at idle.
Old Sep 30, 2006 | 12:54 AM
When troubleshooting this, make sure that you don't run the engine hot for too long. Heat will eventually cause damage. You can turn on your heater full blast to help cool your engine when driving. I had to do this while stuck in a trafffic jam in 95 degree weather while in a traffic jam in Chicago. Its very uncomfortable, but will help cool your car down.
there are a couple things it could be: clogged radiator, bad water pump, or your cooling fans arent engaging when the car is at idle. Sounds to me like you have a cooling fan problem.
Are you losing radiator fluid at all?
I would start troubleshooting with the easiest then work up to the harder stuff. (Fans, temp sensor, plugged coolant system, thermostat, then water pump)
To test the fans:
Since air moving through your radiator when accelerating cools the engine, check your fans. Open the hood and see if the fans are working when you are overheating at idle.
Turn on your A/C and make sure that that both fans turn on.
If they work with the A/C on and not when overheating, then something is wrong with the fan circuit. Check for ~12 volts at the plug for the fan when overheating with a voltmeter.
Check fuse for coolant temperature switch, radiator fan relay and condenser fan relay.
If the fans are ok, then you will have to move on to the temperature sensor.
Old Sep 30, 2006 | 02:47 AM
addicted2blue
i recently had this problem, raditor blew at 181k miles, then 184k miles this problem occured, problem was the thermostat, replaced it and the gasket just before i went on a trip, durin the trip i was stuck in traffic jam 2 times, 1st was for 2hrs and the 2nd was 3 hrs, not once did the hand ever try to raise over normal.
Old Sep 30, 2006 | 03:20 AM
PIGGEBANK's Avatar
I forgot to mention that I bought an aftermarket lightweight radiator about 10 months ago... so I'm not sure if the clogging or leaking would be a problem, may be the fans, I will wait until daylight then go out and check.
Old Sep 30, 2006 | 04:55 AM
deserthonda's Avatar
if you go to our DIY section there is a post about overheating.. look it up ..
Old Oct 1, 2006 | 04:47 AM
PIGGEBANK's Avatar
I did nothing to fix it, but the problem seems to have stopped... odd.
Old Oct 1, 2006 | 05:08 AM
let us know if it happens again
Old Oct 1, 2006 | 06:36 AM
WhyNotFab's Avatar
I wish I had this kind of luck where problems fix themselves!!
Old Oct 1, 2006 | 08:18 PM
i had a similar issue a couple of months after getting my accord, there was a coolant leak coming from what looked like the bottom left side of the radiator, I flushed it, refilled it and put a new cap on and all of a sudden it quit and havent had a problem since.
dpc386
Aug 9, 2011 10:34 AM
troc88
Apr 21, 2011 06:14 PM
Krmnnghia
Aug 26, 2009 07:24 PM
d_10
Jun 27, 2007 10:01 PM
Joshporsche
Jun 14, 2006 10:07 PM
