car won't shift out of park.
does anyone know what the problem might be? right now i'm just sticking my key into the side thing to get it to shift into neutral so i can start the car and go to work. I push the button in, but it won't shift from Park to reverse.
RE: car won't shift out of park.
do a quick test and see if your brake lights come on when you press the brake pedal. If not then it's most likely a brake pedal switch. If they do then there is another shift lock sensor in the center console that gets gummed up over time and can cause this quite easily and is the second most likely culprit.
From page 1 of the DIY section: https://www.hondaaccordforum.com/CAN...m_83974/tm.htm
Follow the instructions. if you have any questions after you read what that thread says, ask away!;) |
Originally Posted by 00AccordLX5spd
(Post 93166)
had this issue !
check for recalls on the car and ignition switch
