car won't shift out of park.
Old Dec 24, 2007 | 09:01 AM
Gomez's Avatar
Default car won't shift out of park.
does anyone know what the problem might be? right now i'm just sticking my key into the side thing to get it to shift into neutral so i can start the car and go to work. I push the button in, but it won't shift from Park to reverse.
Old Dec 24, 2007 | 10:56 AM
sir_nasty's Avatar
Default RE: car won't shift out of park.
do a quick test and see if your brake lights come on when you press the brake pedal. If not then it's most likely a brake pedal switch. If they do then there is another shift lock sensor in the center console that gets gummed up over time and can cause this quite easily and is the second most likely culprit.
Old Dec 26, 2007 | 11:16 AM
00AccordLX5spd's Avatar
Registered User
From page 1 of the DIY section: https://www.hondaaccordforum.com/CAN...m_83974/tm.htm
Follow the instructions. if you have any questions after you read what that thread says, ask away!
Old Jun 16, 2016 | 08:23 AM
tferstl's Avatar
The link don't work?
Old Aug 30, 2019 | 07:19 AM
Angela Michelle Smith's Avatar
Default had this issue !
check for recalls on the car and ignition switch
osiris3mc
Jan 22, 2013 06:42 AM
drfence
Apr 30, 2012 05:10 PM
83Daley
Jul 7, 2009 09:10 PM
foxylady23
May 14, 2008 12:50 AM
badxdawgx818
Apr 4, 2008 12:59 PM
