2002 Accord Won't Shift Out Of Park
Old Jul 6, 2009 | 09:13 PM
83Daley
Default 2002 Accord Won't Shift Out Of Park
Help please.
2002 Accord will not shift out of park. Yes, I did try depressing the brake.
Old Jul 6, 2009 | 09:50 PM
Sweagle02's Avatar
Originally Posted by 83Daley
Help please.
This is a common problem actually. On your gearbox, you will see a little slot next to the shifter, like a plastic tab. That is the shift lock release. Pop out the tab and stick a key or a screw driver in the shift lock release and see if that works. A blown out brake light or brake light fuse might also be the problem. Hope this helps. Let me know!
Old Jul 7, 2009 | 09:30 AM
Also check to see if your brake lights work. Another common problem is a bad switch at the brake pedal.
Old Jul 7, 2009 | 03:34 PM
83Daley
Thank you both for your help.
Old Jul 7, 2009 | 09:10 PM
Sweagle02's Avatar
Sure man, let us know how it goes.
Gomez
Aug 30, 2019 07:19 AM
TrendiNC
Jul 2, 2013 12:25 PM
TrendiNC
Jun 11, 2013 12:15 AM
Clean99V6
Mar 4, 2007 12:49 AM
