Car won't start please help!!
Old Sep 8, 2011 | 08:36 AM
Jojo97's Avatar
Default Car won't start please help!!
I've got a 97 accord f22b vtec, and none of the gauge cluster lights will come on when the key is in the on position, and the motor won't run, it will crank but won't start. I replaced the distributor maybe I put it in wrong. I'm not sure please help!
Old Sep 8, 2011 | 09:13 AM
Since you replaced the distributor, does thae mean you had shown it to be lack of spark?
Old Sep 8, 2011 | 09:32 AM
Jojo97's Avatar
Yea, but I just got it to start! I put the battery on charge for bout an hour then it started right up.
Old Sep 8, 2011 | 10:25 AM
D-ODD-1's Avatar
check the alternator and see that is working.
Old Sep 8, 2011 | 12:10 PM
If gauge cluster lights are not on, this usually indicates a failed ignition switch assy. Easy DIY replacement.
Check for 12V on Blk/Yel wire at distributor when no-start condition is present. If voltage is missing, ignition switch is indicated.
Old Sep 8, 2011 | 03:27 PM
Jojo97's Avatar
Alright, Thanks for the help guys, I'ma check it out
Old Sep 11, 2011 | 09:04 PM
Jojo97's Avatar
Well I checked the blk/yellow, wire and it reads between 12.71v and 12.72v
Old Sep 11, 2011 | 09:42 PM
Originally Posted by Jojo97
...and none of the gauge cluster lights will come on when the key is in the on position...
Does the Check Engine Light come on for at least 2 seconds and then turn off or does it not even come on when you turn the ignition on?
Old Sep 11, 2011 | 09:59 PM
How did you verify that you are missing spark?
Did you check for any engine codes?
Old Sep 12, 2011 | 01:40 AM
Jojo97's Avatar
Not a signal light comes up on the guage cluster, the only thing that works is the radio. The power windows won't even work.
