Center Console Armrest
Old Oct 2, 2013 | 04:35 PM
bshow's Avatar
Default Center Console Armrest
2009 EXL-V6. Armrest vinyl is cracked and needs replaced. How do I remove the armrest? Do I have to replace the whole assembly (83450-TAC-A11ZB) or can I just buy the padded part or maybe take it off and have recovered?
Old Oct 3, 2013 | 04:29 AM
It looks like you have to buy the whole piece if you go through Honda. A place that does car interiors my be able to reupholster it.
Old Oct 5, 2013 | 04:42 PM
bshow's Avatar
Yes, but how do I get the armrest off the console?
Old Oct 6, 2013 | 07:41 AM
Check your e-mail
Old Sep 10, 2014 | 02:32 PM
cellphone's Avatar
Poorman212, can you please send me this information to me also? I can't figure out how to separate the cover from the slide so that I can recover the lid. Thank you.
Old Sep 10, 2014 | 05:16 PM
I've e-mail the same instructions I sent the other user to the account you used to sign up to the forum. It is in an Excel file, the instructions are on different "tabs" in that file. Hope it works.
Old Sep 15, 2014 | 04:44 PM
tommain's Avatar
poorman212, I would appreciate those instructions as well, if you don't mind
Old Sep 17, 2014 | 05:29 PM
"tommain" - Excel file has been sent. As stated before, there are tabs in the file that have different pieces of the instructions/diagrams. Been traveling so I'm behind on reading....sorry.
Old Sep 23, 2014 | 10:31 PM
cellphone's Avatar
Poorman, I have the excel file but I hope I don't have to remove the entire console just to separate the cover from the slide. I just want to recover the top where it has worn out. Some have mentioned inserting a screw driver between the two to release the lock but I've had no luck. Any advice?
Old Sep 23, 2014 | 11:12 PM
If you only want to replace the top, remove the seven screws.
How To Reupholster Center Armrest - Drive Accord Honda Forums
