Changing Alternator - need help
Old Feb 25, 2008 | 11:06 PM
Mrheat's Avatar
Default Changing Alternator - need help
I've ran into a frustrating obstacle in an otherwise easy job. Do any of you know some easy way to get the bottom alternator bolt out? It's crammed in there pretty well. I can't get a wrench to function in the space provided. Is there a special type of wrench I should use, or a special angle to come in from? Also, since I haven't really been able to tell, is it a 14mm or a 13mm? The top one was 14, but it felt like the 14 was too big on the bottom one. I appreciate any ideas...I can't believe what a headache one little bolt can be.
Old Feb 26, 2008 | 08:54 AM
00AccordLX5spd's Avatar
Registered User
Default RE: Changing Alternator - need help
Can you get a socket extention in there? Like an extention you would use to change your plugs? Have you tried any non-metric(standard) sizes in case the alternator has been changed out before and some mechanic installed a non-metric nut?
Sorry, I haven't changed an alternator on either ofmy Hondas yet (knocking on wood right now.) But I changed one not too long ago on my Mustang.
Old Feb 26, 2008 | 07:00 PM
hondadude's Avatar
That bottom bolt is a 12mm;I have a SEMI-DEEP socket for that. I've also used a short offset box end for that.
Old Feb 27, 2008 | 06:34 PM
It can be a real pain to get just right amount of reach between the body, drive belt,and the nut. I've used 1/4" ratchet w/ stepup adapter and 12mm-3/8" drive socket to have just right amount of reach. If you've managed to round the nut, a sears damaged nut socket will do the job, but you may have to remove the PS drive belt to access.
cacti
Jan 18, 2013 06:29 AM
01SilverAccord
Apr 18, 2012 09:46 PM
aking
Apr 4, 2011 11:19 AM
Antarctica
Nov 18, 2008 07:03 PM
Markus26
May 17, 2006 09:28 PM
