Changing BOTH tie-rod Ends...
Ok.... I have done all the necessarry work to get the tie-rod ends changed.... but I did notice when I disconnected the boot for the inner tie-rod end oil spewed out... What kind of oil should I put back in there??? I am going to use a seringe BTW..
RE: Changing BOTH tie-rod Ends...
There shouldn't be any oil in there. It usually indicates a leaking steering rack.
Could this bad steering rack cause the Inner tie-rod ends to go out??
ORIGINAL: SofireGuy Could this bad steering rack cause the Inner tie-rod ends to go out?? Now... were you replacing the inner tie rods or the tie rod ends??? inner tie rods are the ones that bolt into the rack and need to remove the rack dust cover to replace them the tie rod ends are the ones at the end of the steering rack , and attached to the stering knuckle . |
| All times are GMT -5. The time now is 11:45 PM. |
