Changing BOTH tie-rod Ends...
Old Aug 11, 2007 | 05:51 PM
Guest
Default Changing BOTH tie-rod Ends...
Ok.... I have done all the necessarry work to get the tie-rod ends changed.... but I did notice when I disconnected the boot for the inner tie-rod end oil spewed out... What kind of oil should I put back in there??? I am going to use a seringe BTW..
Old Aug 11, 2007 | 06:27 PM
Chiovnidca's Avatar
Default RE: Changing BOTH tie-rod Ends...
There shouldn't be any oil in there. It usually indicates a leaking steering rack.
Old Aug 11, 2007 | 06:45 PM
Guest
Could this bad steering rack cause the Inner tie-rod ends to go out??
Old Aug 12, 2007 | 01:32 AM
deserthonda's Avatar
ORIGINAL: SofireGuy
No...that means that the seals on the rack are leaking ....depending on how much the rack leaks i would not waste my time replacing inner tie rods,, if you plan on replacing the steering rack the reman rack comes with new inner tie rods
Now... were you replacing the inner tie rods or the tie rod ends???
inner tie rods are the ones that bolt into the rack and need to remove the rack dust cover to replace them
the tie rod ends are the ones at the end of the steering rack , and attached to the stering knuckle .
slickgeek
Nov 6, 2014 02:01 PM
scottindia
Jan 31, 2014 08:27 AM
skinsgamer
Aug 20, 2007 01:10 PM
Tony1M
Jul 3, 2006 08:12 PM
aka1109
Jan 10, 2005 02:19 PM
