Changing the ECU
Old Nov 24, 2023 | 09:23 PM
Maxman1's Avatar
Default Changing the ECU
I did a search for ECU inthe threads but I didn't find any posts. Looking for info on how to get the new ECU working. I heard once about having to get a code so you can get it started to get the new ECU programmed to the vehicle. Any help would be appreciated thanks.
Old Nov 24, 2023 | 10:36 PM
What year accord, engine, trim, automatic/manual vehicle do you own?
Old Nov 25, 2023 | 01:44 AM
Maxman1's Avatar
2004 EX v6 I think it's a baxa automatic
Old Nov 25, 2023 | 10:37 AM
The 98-02 had a procedure to bypass the ECU using the brake pedal, where you would you could bypass the security for a one-time drive to get it to a shop. The 03-07 accord doesn't mention this type of situation in the shop manual.
Based on the shop manual, it looks like you need a Honda Scanner or some expensive scanners can do program. You can call a dealership to find out if there is an over-ride option, but I suspect the vehicle may need towed to the shop. You can also look into independent shops or a locksmith to see if they can program the keys and the other programming items. Maybe some mobile mechanics could do the programming?
Infinite1
Aug 27, 2012 11:32 AM
XxBladesxX
May 4, 2012 06:13 PM
Adie
May 14, 2006 09:17 PM
accordinprogress
Dec 6, 2005 09:41 PM
Chadd122
Sep 15, 2005 09:10 PM
