Changing rear drum brake pads /1998 Accord LX
Old Dec 9, 2007 | 11:04 PM
Default RE: Changing rear drum brake pads /1998 Accord LX
Looks to me like there IS an adjustment. A rubber plug in the back plate (#13) & the adjuster wheel (#18, 24).
But... If that were the problem, you'd feel the brake drum come loose from the hub (#1), & then you'd feel the shoeshang up on the ridge worn into the drum.
If the drum is seized to the hub, you could work it with some PB Blaster or Liquid Wrench or something like that.
Old Dec 10, 2007 | 05:56 PM
396rat
Jimblake
A few weeks ago I slid under and did see the oval rubber plug on the backing plate. I removed it and looked around but could not find anything in there that would help me bring the shoes in. I plan on using Hondatec Av6 or deserthonda idea.
Thanks
Old Dec 10, 2007 | 07:06 PM
deserthonda's Avatar
the adjustment star is there,, but it is real hard to get to it and adjust the shoes,,very limited space.. I have found that it is a lot easier to just remove the drums and adjust the shoes that way .
reason why drums would not come off....
inner part of it, frozen in the hub,, wd-40 (or equivalent )and a few hit with the hammer will loosen it up
shoes too tight , but if that would be the case then the drum would not turn or very hard to turn
deep lips ( grooves) on the inner drum, drums need to beturned ( machined ) or replaced .. and if that is the case, shoes would have deep grooves as well and would need to be replaced
Old Dec 10, 2007 | 10:26 PM
Well, the ones that have given me trouble, they've beenstuck because of a deep lip on the drum. And you can feel it come loose from the hub. That's the specific case where you'd have to use the starwheel or else force them off & destroy some littlehardware bits.
Old Dec 11, 2007 | 03:57 PM
396rat
JimBlake
So there is a starwheel and it can be backed off. Is the starwheel on the top or the bottom.
BTW is it me or this site, I cant seem to have Firefox remember the login info here.
Old Dec 11, 2007 | 05:49 PM
Looks like it's at the top. I just have the picture I posted, I can't remember real clearly...
If you don't see the picture, try this.
http://www.hondaautomotiveparts.com/...13s840_j03.gif
Old Dec 11, 2007 | 05:51 PM
  #17
Jim is correct ,,,,,, definately at the top..
Old Dec 11, 2007 | 05:56 PM
  #18
396rat
Thanks to all!!
Glade I found this place!
Old Dec 11, 2007 | 06:07 PM
  #19
sir_nasty's Avatar
didja git r done?
Old Dec 11, 2007 | 10:18 PM
  #20
ORIGINAL: sir_nasty
didja git r done?
LOL,,LOL,, your tink u funny Sir ??
