Check engine light on
Old Jun 10, 2014 | 11:59 PM
OBD1 is less specific. For example, a MAP sensor can fail with high or low voltage, or open. OBD2 would have a code for each of those failures. OBD1 would give a code for a MAP sensor and have you do all three tests.
FYI, there are only three sensors that are different between the OBD1 (94/95) and the OBD2 (96/97) 5th generation accords, so the testing is basically the same between them.
Checking the OBD1 way is useful when you can't drive your car to the parts store. It also takes about five minutes of your time to test.
Old Jun 18, 2014 | 11:19 PM
woody31's Avatar
Almost A Senior Member
ok i checked it,,the D is blinking ,,either it is 14 or 44?? also the check engine light is blinking 77,,,,any ideas,,thanks
Old Jun 19, 2014 | 07:01 PM
woody31's Avatar
Default bump,,
bump,,anyone???
Old Jun 19, 2014 | 07:17 PM
I don't have any of those codes in my 96 manual.
When shorting the connector, the light will come on for about two seconds, turn off for about two seconds, then start flashing the code. A long blink =10, and short blink =1. So LLLL SSS = code 43.
You may want to stop by a parts store and have the scanner hooked up.
Old Jun 19, 2014 | 10:37 PM
woody31's Avatar
thanks for the reply,,,ill give a parts store a shot at it and report back
Old Jun 21, 2014 | 09:53 AM
I saw a PM where you said the CEL could be a 17. That I can find next to P0500, an issue with the VSS.
Still couldn't find 14 or 44 for the trans, but if the CEL is the 17 then I could see where the trans would also set a code. Is is possible the the D4 light is a code 4 as that would also point towards an issue with the VSS?
Again I would still stop by a parts store and ask them to read the code - get the code number from them and not thier "description" of the issue.
Old Jun 21, 2014 | 10:15 AM
  #17
woody31's Avatar
ok will do,,thanks for your time and reply,, i will be in touch with you soon,,,semper fi,,
Old Jun 21, 2014 | 10:51 AM
  #18
That picture/avatar is actually a tribute to my oldest son. It was taken just after he graduated from OCS USMC.
But yes - a big thanks to everyone who has/is serving our country
Old Jun 21, 2014 | 11:02 AM
  #19
woody31's Avatar
Yes I am familiar with your "story" . Hope you have a good weekend.
Mott
Mar 15, 2016 11:25 AM
ddold@gkschools.org
Jan 29, 2008 03:35 PM
hotrod01
Nov 11, 2005 01:28 AM
