Checking for vacuum leak
I think that before going any further with the troubleshooting of the Cruise Control, I want to check for a vacuum leak. I have used staring fluid in the past on my V8's but I know it dries out the cylinder walls and isn't really that good for the engine. Does anyone think they can forward some slick way to check for a vacuum leak that will give a quick result like the starting fluid does? thanks
I've used WD-40 on carburated vehicles in the past for exhaust leaks and want the same principle for the vacuum leak using the starting fluid. I know too that the starting fluid dries out the cylinder walls and is not good for any motor, but hey, if you need some help, you need to bite the bullet if that is what will get you to where you need to go.. I was just wondering if maybe I could hook up something if I knew the principle that they used but knowing "how" they make the smoke... thanks for the reply
Don't know how to do it with out the machine, but they heated the "baby oil" to make smoke, and with very low air pressure push the smoke through whatever you think has vacuum is leaking. If smoke come out from anything then there is the leakage.
The tiny amount of throttle body cleaner that would actually enter the engine at a leak site will not harm the engine. This chemical evaporates readily and would never reach the cylinder wall in liquid form. In gas form, it's just fuel.
