chugging?
Old Sep 16, 2013 | 03:23 PM
  #21
Sorry, about 91 manual. My 90 Manual has it. It looks like the download manual is an overseas manual w/ much simpler EGR system.
Yes, you plug the EGR vacuum line after removing from the EGR valve. At idle there should be no vacuum. At 2000 rpm steady, there should be vacuum. If you have vacuum all the time the EGR solenoid valve is likely stuck in open position.
Old Sep 16, 2013 | 10:25 PM
  #22
hondadude's Avatar
Engine temp sensor could be misleading the computer.
You can try cracking open the throttle 1/2 way when cranking the hot engine to see if that helps the problem
Old Sep 17, 2013 | 09:15 AM
  #23
drummer1279's Avatar
should I do this EGR test on cold or hot engine?
Old Sep 17, 2013 | 10:51 AM
  #24
Cold engine is when chugging occurs, so test that way.
Old Sep 18, 2013 | 08:10 AM
  #25
its actually when its hot that the chugging happens. however yesterday it did not do it at all *smh*.. but, I still did the EGR test both cold and hot, at idle no vacuum, and at 2k RPM, I couldn't really feel any sort of suction either. The ambient temperature was 15 degrees cooler than it has been as well; don't know if that would have anything to do with it behaving differently.
Old Sep 18, 2013 | 10:41 AM
  #26
Did you perform any coolant checks to rule out head gasket?
EGR test suggests EGR is working correctly. It can be hard to detect EGR vacuum w/o a gauge.
Old Sep 18, 2013 | 09:26 PM
  #27
I didn't do the exhaust gas test, but my spark plugs are all dry, and my motor oil shows no signs of coolant mixing with it.
Old Sep 20, 2013 | 03:56 PM
  #28
Ok HOndadude, I held the throttle halfway open and started the car when it was hot, all it did was sputter and chug at a higher RPM and nearly choke down when I let my foot off the pedal.
jaffadog
Feb 6, 2015 01:16 PM
ghostpilot
May 25, 2011 12:06 PM
byrothapyro
Oct 5, 2010 04:58 PM
tris320
Jun 16, 2010 11:08 PM
88accord
Dec 20, 2007 02:56 PM
