Cleaning Headlights
Old May 18, 2012 | 08:49 PM
Dr. Drivability's Avatar
As mentioned, 1500 grit wet sand them, dry and tape off the paint area, pick up some Mequires Plast-X and use a a drill with a foam buffing pad on it, can also be done by hand. Then go charge your neighbor 25 bucks to do his and you'll pay for the supplys plus a case of beer
Old May 18, 2012 | 09:03 PM
GoneHonda's Avatar
Originally Posted by dr. Drivability
then go charge your neighbor 25 bucks to do his and you'll pay for the supplys plus a case of beer
hahaha i should have done this!
Old May 18, 2012 | 10:22 PM
94ex915's Avatar
Almost A Senior Member
Originally Posted by Frederick
you can browse some hid lights at uobd2
Just bought HIDs today and you can tell more then ever that the light is messed up. Picked up this turtle wax restoration kit and it helped a little but its a little windy now so I really didnt do a good job on it. Will try again in the morning and if not ima get some sandpaper..
Old May 18, 2012 | 10:51 PM
EXV6NIGHTHAWK's Avatar
The Turtle wax kit is a lot of work, and doesn't really do any better job than the Mothers powerball kit, which is much easier to use. It doesn't last forever either way, but at least doing it again is easy with the powerball. Sand paper comes with the kit, but I didn't need to use it.
Old May 19, 2012 | 12:18 AM
94ex915's Avatar
Ya but the sand paper provided is really small so im going to try the 1500 tomorrow. By the way, do you know how to adjust the headlights on this car?
Old May 19, 2012 | 12:32 AM
Doesn't make sense to me to use sand paper at all, when it's not neccessary, but whatever works for you. Put the powerball on a drill, a little liquid on the ball, and in a few minutes you have clear headlights again.
Old May 19, 2012 | 05:46 AM
  #17
crispin's Avatar
It really depends on how damaged the lens are to start.
It sounded like the OP's car needs a lot of smoothing as he says he can feel the roughness with his hand.
I used the sandpaper on a Tahoe once that was in really really bad shape and I have used just the polish on a few lenses that were just lightly discolored.
Old May 19, 2012 | 03:18 PM
  #18
94ex915's Avatar
Ya they are bad. Havent worked on it yet. Anyone tell me where the adjustment screws for the headlights are?
Old May 19, 2012 | 03:49 PM
  #19
I think there is only one adjustment (up and down), and you have to use a long screwdriver going through the plastic piece under the hood. I've tried it before, and I've never gotten the light to move very much. Protect the area around the headlight with tape.
What I like about the powerball is you can use the sandpaper the first time, then use the ball to maintain it after that. It will get dull again, in half the time, so you will need to do it again.
Old May 19, 2012 | 06:50 PM
  #20
94ex915's Avatar
Anyone have a picture of where I adjust it at? I cant find it.
