Climate control panel
I have a 99 honda accord ex4 cyl i have a problem with the climate control panel on the car it comes on for 20 min when i turn the car on then blinks a few times and then goes dead i have changed all the fuses related to the a\c and fans i think its a relay that feeds power to the climate panel i have heard it click while the panel blinks it sounds like its coming from the blower moter under the glove box i bought the repair book from pepboys but there is no info on a relay in the area can someone help
thanks |
RE: Climate control panel
I have the same problem with a 99 accord, only now the a/c control panel is dead!! It was intermittent like yours. Did you find your problem???? Please let me know what your results were. I am a senior citizen and can't afford to pay for service.
thanks....have a great day |
I finally found the problem I took it to the dealer they said the problem is in the climate control panel they WANTED 489 DOLLARS
i said no way too much money I then went on ebay and picked one up for 32.99 thats including shipping it took 20 min to install very easy to do,let me know how everything turns out my a/c now works great 99 honda accord ex 4 cyl |
Thanks alot; I will do the same. Peace to you..
I bought a climate control panel on EBAY, installed it and my problem is gone. The A/C works great....so, all of you people out there that have intermittent climate control panels and dead panels on 99 honda accordsIt's the DADGUM climate control panel and it's easy to replace!!
Watch out for the "spring" in the hazard switch next to the clock-It will fly through the air when you disconnect the cable harness behind the hazard switch. This is about a 30 minute job. I'm almost 70 years of age and if I can do it, you can toosave yourself some money.. I was dissapointed with this forum that only one person helped me out, only because he had a similar problem. You "EXPERTS" out there should be ashamed of yourselves for being out there and NOT helping. "What goes around comes around". Just be a good neighbor and help someone out. Thank you bug176, you are my hero; my wife can now drive her car in the HOT Florida heat and I don't have to drive her to the beauty parlor to get her hair done. ha.. |
ORIGINAL: caboose I was dissapointed with this forum that only one person helped me out, only because he had a similar problem. You "EXPERTS" out there should be ashamed of yourselves for being out there and NOT helping. "What goes around comes around". Just be a good neighbor and help someone out. Thank you bug176, you are my hero; my wife can now drive her car in the HOT Florida heat and I don't have to drive her to the beauty parlor to get her hair done. ha.. Given your experiance in life, you should be ashamed of yourself. Furthermore, if you got your answer, why should anyone else repeat the same answer? |
| All times are GMT -5. The time now is 06:53 AM. |
