Clunking Sound when Make a fast Turn/ Brake Fluid Low
Old Jan 29, 2008 | 12:18 PM
kennilope's Avatar
Default Clunking Sound when Make a fast Turn/ Brake Fluid Low
Hi there...
I m back for help again..
Been Away for awhile.
Anyway
here is my problems:
Everytime I make a fast turn Mostly the right turn.. I hear a clunk clunk sound on the passenger side. Dont know if it is be back or front...
Sometime it is for the left side too..... I dont knw what is wrong with it...
Second problem is lately.. My brake fluid always go low.... Feel it up a month or so later it go low again... I check for any leak i dont see .
Does anybody know what happen??
I think it is the passenger front wheel.... not sure... but i think it is somewhere there.
Thanks for the help....
This place is the best.
Old Jan 29, 2008 | 12:22 PM
sir_nasty's Avatar
Default RE: Clunking Sound when Make a fast Turn/ Brake Fluid Low
Find a parking lot and do a tight turn nearly as hard as you can all the way to the left then all the way to the right and see if you get a clicking noise. As for the brake fluid, start tracing your brake lines, it has to go somewhere....
Old Jan 29, 2008 | 04:59 PM
nafango2's Avatar
the clunking noise could be the rubber in your sway bar linkage (or lack thereof)
also could be your CV's lack of grease (as sir_nasty said)
or a whole mess of other things, those are just the two most common.
Cory Demetrius Moultrie
Apr 25, 2013 08:08 PM
sneak
Sep 30, 2012 02:20 PM
welly_89
Apr 17, 2012 08:07 AM
thunder_x
Nov 30, 2007 12:57 PM
HondaAccordNewb
Oct 18, 2007 06:51 AM
