Clutch?
Well I just got my car all tuned up and the brakes done, and wouldn't you know it. The darn thing is making a noise when I use the clutch. When I push the clutch to the floor the noise goes away, when I let off the clutch the noise comes back. Seems to be a loud humming noise. A buddy said it might be the throwout bearing. After doing a little online research I have figured that this is probably the problem.
My car is a 1995 Accord EX 4cyl. any input from anyone on a certain brand of clutch kit I should get for this car? This car is used for normal daily driving. Nothing souped up on this car. |
Try this...
Put it in neutral & have the engine running. Engage the clutch (let out the pedal). It should be making the noise now. Disengage the clutch suddenly (press the pedal down suddenly) & listen. A bad throwout bearing should get quiet almost instantly. A bad transmission-shaft bearing will take a second or 2 before it coasts to a stop. Also, a bad throwout bearing should get quiet if you just press the pedal down a small amount. That puts a small thrust-load on the throw-out bearing to hold it together. A bad trans-shaft bearing will still be spinning until you press the pedal all the way down. |
Thanks Jim I will try this. If it is a bad throwout bearing or a bad transmission shaft bearing does that mean that I should do the clutch while i'm in there?
if noise goes away when you depress the clutch pedal , it is a bad input shaft bearing ..
if noise does not bother you ,, you can drive the car ,, I have seen trannies with bad bearing ( noisy ) drive for several years ,,,,,,,if noise stays the same drive it if noise gets louder ( daily, weekly ) then it is time to repair tranny ,, get a used tranny cheapest way to go about it |
Yeah, no matter what makes the noise, a BIG part of the job is removing the transmission from the car. So you should really think about a new clutch while you're in there.
