Clutch?
Old May 25, 2010 | 10:03 AM
steeleywhopper's Avatar
Default Clutch?
Well I just got my car all tuned up and the brakes done, and wouldn't you know it. The darn thing is making a noise when I use the clutch. When I push the clutch to the floor the noise goes away, when I let off the clutch the noise comes back. Seems to be a loud humming noise. A buddy said it might be the throwout bearing. After doing a little online research I have figured that this is probably the problem.
My car is a 1995 Accord EX 4cyl. any input from anyone on a certain brand of clutch kit I should get for this car? This car is used for normal daily driving. Nothing souped up on this car.
Old May 25, 2010 | 10:57 AM
Try this...
Put it in neutral & have the engine running.
Engage the clutch (let out the pedal). It should be making the noise now.
Disengage the clutch suddenly (press the pedal down suddenly) & listen.
A bad throwout bearing should get quiet almost instantly.
A bad transmission-shaft bearing will take a second or 2 before it coasts to a stop.
Also, a bad throwout bearing should get quiet if you just press the pedal down a small amount. That puts a small thrust-load on the throw-out bearing to hold it together. A bad trans-shaft bearing will still be spinning until you press the pedal all the way down.
Old May 25, 2010 | 05:59 PM
Thanks Jim I will try this. If it is a bad throwout bearing or a bad transmission shaft bearing does that mean that I should do the clutch while i'm in there?
Old May 25, 2010 | 07:56 PM
deserthonda's Avatar
if noise goes away when you depress the clutch pedal , it is a bad input shaft bearing ..
if noise does not bother you ,, you can drive the car ,, I have seen trannies with bad bearing ( noisy ) drive for several years ,,,,,,,if noise stays the same drive it if noise gets louder ( daily, weekly ) then it is time to repair tranny ,, get a used tranny cheapest way to go about it
Old May 25, 2010 | 09:09 PM
Yeah, no matter what makes the noise, a BIG part of the job is removing the transmission from the car. So you should really think about a new clutch while you're in there.
vetski179
Feb 24, 2015 04:26 PM
clutchless
Mar 8, 2011 11:50 AM
JimBlake
May 18, 2009 09:38 PM
tamb
Jul 21, 2006 01:05 AM
Nov 4, 2005 09:54 PM
