-   -   Clutch clutch clutch (https://www.hondaaccordforum.com/forum/general-tech-help-7/clutch-clutch-clutch-4095/)
tamb Jul 18, 2006 05:50 PM
Hey gang,
I have a 2000 Accord, 200,000km 5 speed VTEC.
I have recently changed the clutch, fly wheel was ok, but I find this clutch is wearing very quickly. I also have a sqeek or squak when i depress the clutch pedal. Are the two problems related? The squak has been there since before the clutch change. I would hate to have to tear my car apart again to change the clutch so I'm hoping there is another solution. Could it just be a bad clutch?
Tamb
deserthonda Jul 18, 2006 11:17 PM
RE: Clutch clutch clutch
does it squeak only when you push the pedal up and down ?? did you lube the fork oivot when you had the tranny off?
try something.. pull the rubber boot off where the clutch fork is at slave cylinder, have someone depress the clutch pedal back and forth, get a can of wd-40 and spray where the fork pivots ..
as for clutch wearing very quickly ,, do you ride the clutch?? ( keep the foot on it ) ?? was it a cheap clutch assembly ??
lightshow Jul 19, 2006 03:18 AM
does you clutch chatter or shudder when you engage it? if it does, then thats because you didnt have the flywheel resurfaced when you changed out the clutch.
tamb Jul 19, 2006 11:16 AM
I will try the WD40, it only squeaks when i press and let out the clutch, usually when its closest to the floor. The Squeak isnt the pedal itself, but I can feel it in the pedal.
As for riding the clutch, no. I bought my car with 130,000km on it and I put the last 70,000 on the clutch before it went. The clutch assembly was not made by Honda, just OEM quality.
And no, there is no shudder when I let out the clutch.
My poor Honda
mbo1985 Jul 19, 2006 10:25 PM
How fast is it wearing out? Can you smell burnt clutch? Or is it losing grip?
tamb Jul 20, 2006 06:21 PM
I've had it on for about 6 weeks now. When I first put it on it grabbed when the pedal was 1/4 of the way off the floor, now its more like 3/4.
mbo1985 Jul 21, 2006 01:05 AM
it *could* be the clutch just wearing in. If you really think there is a problem though, you're probably right.
