Codes and Action to Take
Hello all,
just purchased a '98 from a friend. Car is in great shape with only 136K on it. The check engine light was on and I had it in the local shop. It came back with four codes, they checked them all out and said things looked fine and to let them know if it comes back on. It came back on the following day so I am curious if anyone knows how serious they are. I'll bring the car back but have a big driving trip this weekend and would prefer to deal with this afterward. The car runs fine. Here are the codes: P1456 Evaporative System Leak P1491 EGR Circuit Fault P1259 V-TEC Oil Switch Circuit P0401 EGR Insufficient Flow Also, I apparently have the original wire and dist cap. How difficult are these to change? Thanks! |
Hello Member...
Originally Posted by misterpatrick
(Post 246747)
Hello all,
just purchased a '98 from a friend. Car is in great shape with only 136K on it. The check engine light was on and I had it in the local shop. It came back with four codes, they checked them all out and said things looked fine and to let them know if it comes back on. It came back on the following day so I am curious if anyone knows how serious they are. I'll bring the car back but have a big driving trip this weekend and would prefer to deal with this afterward. The car runs fine. Here are the codes: P1456 Evaporative System Leak P1491 EGR Circuit Fault P1259 V-TEC Oil Switch Circuit P0401 EGR Insufficient Flow Also, I apparently have the original wire and dist cap. How difficult are these to change? Thanks! WheelBrokerAng |
They took a look at what the codes reflected and said everything looked fine and there was nothing to fix that they could see. If the check engine light came back on they said they'd do further investigation.
1 Attachment(s)
(Post 246754)
If your shop checked out the codes and didn't fix them...what did they do? erase the codes and send you down the road?
WheelBrokerAng See what the next shop says..if the codes are all the same after they read them..ask them how much to fix..and what their repair warranty covers on their work.. Angelo :) |
Those codes are nothing that would cause immediate problems. Did you tell the shop that you didn't want to do repairs presently? That may be why they reset the codes and returned car to you "as-is".
There are repairs required to fix these. Nothing enormous, but certainly several hundred dollars in repairs. I hope these figured into your price. good luck |
Thanks. They said nothing in the codes was a major issue which is why they reset the check engine light and told me to keep an eye on it. I just wanted to make sure it's nothing major and something I can put off for a few months. They said other than the codes, the car looks great but while the plugs are new, the cap and wires are the original so I should replace those at some point.
I got the car from a friend who left the country for work so I paid next to nothing for it so I'm fine paying for the repairs. The shop I go to is a stand-up place. Most of the guys working there play softball with my brothers and have been working on our family cars for twenty years. I just wanted to get some other opinions on what to do, and as I plan on making a lot of the minor repairs myself, thought I'd start using this forum. Thanks for the feedback!
(Post 246759)
is this a 4 or 6 cylinder accord?
I actually don't know - I've been too busy to take a look. It's the 4-door sedan 5-speed manual.
| All times are GMT -5. The time now is 09:44 AM. |
