cold starting probs
Old Jul 19, 2013 | 07:14 PM
spsweet's Avatar
Default cold starting probs
ok I just purchased a 94 accord ex with the 2.2 liter 4 cyl . in the morning when I go to start it wont start. if I cycle the key switch a couple of times it will start and run for two seconds and then quit. I used a whole can of carb cleaner to get itt to run ...... once I get it to run and warm up it starts just fine, but aftyer sitting all night it wont start in the morning. I am at a loss here ...... please help.
Old Jul 19, 2013 | 07:30 PM
5.56mm_hickey's Avatar
could be number of things, weak fuel pump. when you say cycle the key do you mean cranking the engine, or just cycle accessories? check your plugs and see if there full of fuel or oil. how long does have to sit for this to occur?
Old Jul 19, 2013 | 07:36 PM
spsweet's Avatar
when I say cycle the key I mean turn the key off and back on .... it will start if you do this but quits after 2 sec . also if you don't cycle the key again it wont fire again untill you cycle it
Old Jul 19, 2013 | 07:38 PM
spsweet's Avatar
took me about 20 min of constantly doing this to get it to stay running
once I got it running it was fine. I could shut it off and it would fire right back up
Old Jul 19, 2013 | 07:39 PM
spsweet's Avatar
8 hours
Old Jul 19, 2013 | 07:43 PM
hmmm from your description it sounds more like a ignition switch problem then mechanical
Old Jul 19, 2013 | 07:45 PM
im putting my money on fuel pump for mechanical
Old Jul 20, 2013 | 09:16 AM
Just so I'm clear - when you say it won't start, the starter is spinning the engine over but it won't run on its own....correct.
If the starter is spinning the engine - does it seem normal or is it slower than normal.
Is the CEL on, I'd check for any stored codes.
Old Jul 20, 2013 | 04:48 PM
yes, like poorman said, cycling the key just means to cycle it from off to acc. over and over, but to turn it over and actually engage the starter is starting it. like i was trying to confirm on a couple of post ago
Old Jul 20, 2013 | 08:25 PM
spsweet's Avatar
yes poorman It will spin the engine just fine. doesn't seem to be dragging down or weak. but wont run. if I turn the key off and and back on it will run for 2 sec and then shut off, no light on dash. if I don't turn the key off and back on again and try to start it will just turn over and not run.
