Collapsing power steering hose
Old Nov 13, 2008 | 02:16 PM
gtrplr2
Default Collapsing power steering hose
I have a 1994 Accord Ex 4 cyl coupe. I start it up and let it run for about a minute and it begins doing the RPM surging thing about every 5 seconds. One of the hoses on the power steering collapses completely flat. Are the two problems related? Can a faulty power steering pump cause either of the problems? Any insights leading to resolution will be DEEPLY appreciated.
Old Nov 13, 2008 | 02:57 PM
finch13's Avatar
Default RE: Collapsing power steering hose
Use the link in my signature below to search "surging idle", this is most likely a dirty Idle Air Control Valve.
The power steering hose you mention is likely the hose on the suction side of the pump (this hose goes from the pump to the bottom of the power steering fluid reservoir), the other side is the pressure side. Probably isn't an issue.
lonberge
Oct 1, 2010 07:59 AM
jamesejam
Sep 21, 2009 02:37 PM
fatswany
Oct 11, 2007 05:54 PM
Wilsco
Nov 20, 2006 05:53 PM
Bobby W
Jun 30, 2006 12:15 PM
