A confused 98 Accord EX
Old Oct 2, 2006 | 07:49 PM
cshon1y
Default A confused 98 Accord EX
Somebody please help me. I have a 98 Accord EX 4 cyl. Sometimes when driving and the car hits 4k rpms the engine cuts power like the rev limiter is cutting on. Also, the car sometimes stalls when stopping at a light. I have done a tune up plugs, wires, distributor cap, rotor button, pcv and air filter. Also changed EGR valve. Still no change. There is no set situation which makes the car do this. Any ideas?? Thanks in advance
Old Oct 3, 2006 | 04:33 AM
Slusher's Avatar
Default RE: A confused 98 Accord EX
How long has the car been doing this? It sounds like you might not be getting any fuel, fuel filter change? Check those vaccum lines as well.
Old Oct 3, 2006 | 09:25 AM
Chiovnidca's Avatar
Is the check engine light coming on? Any stored trouble codes?
Old Oct 3, 2006 | 07:54 PM
cshon1y
I just bought it about 3 weeks ago. It doesn't do it all the time so it could have done it with the previous owner. I thought the fuel filter was part of the fuel pump and was considered a "lifetime" filter? The CEL came on today on the way home from work. I am not sure if the mod to the EGR port has been done or not. Is there any way to find out if the mod and or recalls have been done?
Old Oct 3, 2006 | 07:57 PM
Slusher's Avatar
Get the code read at autozone, will be free. Get the vin number and call your local dealership, they can look it up to see if its been done to your car.
Old Oct 3, 2006 | 08:04 PM
cshon1y
Codes are P1259, P0401, P0420. About the fuel filter would I have to change the whole pump?
Old Oct 3, 2006 | 08:09 PM
Slusher's Avatar
Fuel filter is mounted on firewall in engine compartment. You should release the pressure in the fuel system, put rags underneath filter, and then remove. Once you look at it it should be pretty straight forward. If not, let us know, we're here to help.
Old Oct 3, 2006 | 08:17 PM
cshon1y
My Accord does not have a fuel filter on the firewall. Any other suggestions?
Old Oct 3, 2006 | 09:55 PM
Slusher's Avatar
Oh, sorry about that, I didn't see that it was a 98. Let me look around a little...
Old Oct 3, 2006 | 11:18 PM
deserthonda's Avatar
ORIGINAL: cshon1y
p1259......vtec malfunciton,, needs to be diagnosed
p0401.... egr low flow.. most likely you need to have the bulletin done ,, clean the passages
p0420... cat below treshhold,,, most likely need a new cat convertor
My advice take it to the dealer some of this stuff could be an honda extended warranty..
How many miles on car ??
As for the dying it could be the ignit switch , have the delaer chk if the recall has been done ..
