Coolant Question?
drain the radiator by removing the drain plug, to drain the block on the back of the engine left side of oil filter , there is a drain plug , i believe 17mm head, remove it, get a water hose, put it in the radiator and run the water till it comes out clean from the block drain hole, remove the rad drain plug again to drain the radiator, reinstall plugs, open up the bleeder screw 12 mm nipple on the t-stat housing , have a 50/50 mix of colant and water and fill the radiator , till only coolant and no air comes out of the bleeder screw , tighten screw ,,start car up and let it run a bit without rad cap on , top off coolant if need to, install rad cap. Also make sure to empty reservoir and install new coolant there as well..
