cooolant
Old Jul 30, 2008 | 03:27 PM
rhobere's Avatar
Default cooolant
I drive an 02 ex-v6. Does anyone know if the throttle body and the intake manifold share the same coolant line or if the intake manifold's linecomes in from somewhere else. I'mgoing to reroute the coolant lineso that it will bypass the throttle body and I wanted to know if that would also bypass the manifold.
thanks,
heather
Old Jul 30, 2008 | 04:50 PM
falkore24's Avatar
Default RE: cooolant
Just couple the TB lines together.
Old Jul 31, 2008 | 02:06 PM
rhobere's Avatar
Alright, I know that I need to couple the throttle body lines together. My question was if the manifold and the throttle body SHARE that coolant line or if I'm going to need to reroute/block a different line to bypass my manifold.
thanks
Old Jul 31, 2008 | 04:11 PM
falkore24's Avatar
The mani is heated? TB is heated to keep it from freezing.
Old Aug 1, 2008 | 11:17 AM
rhobere's Avatar
Me and one of my friends installed a manifold spacer on her s2000and one of the perks of the spacer was that it blocked a coolant line through the manifold. I assume there is one on this manifold too, but I don't know for sure. If there isn't then that's just one less thing I have to do I guess.
