Couple of questions for you guys and gals
Old Sep 1, 2009 | 01:01 PM
freeze101
Exclamation Couple of questions for you guys and gals
Hi all
I have a 1999 20ies accord and I need to do a couple of jobs on it first I need to change the upper wishbone on the front end both sides I have bought the new wishbones but I have just had a look and it seems like the bolt are fouled by the shocker?so do I need to remove this before I can remove the wishbone or will their be room to get the bolts out ?
secondly:
I am attemting to change all brake pads and disc's /rotor's I have done the front ones no problems but the rear ones are becoming a right pain I have the piston wind tool to take the piston back but it wont budge it is really tight I am just wondering if their is something I am doing wrong or something I have to do first before winding it back?
any help will be great;y appreaciated
thank you
freeze
Old Sep 1, 2009 | 01:32 PM
Describe your "piston wind tool". Does it push the piston straight in? The rear piston needs to rotate in, like you're tightening a bolt. Clockwise to retract the piston & make room for new pads. (That's all because of the handbrake auto-adjust mechanism.)
Old Sep 1, 2009 | 05:48 PM
freeze101
hey thanks for the reply
Sorry I should have said at first yes it is the kind that rotates and compresses at the sme time as I have done my homework and found out about the hand brake mech as you have kindly mentioned, Its just as I am turning it, it seems very tight and I dont want to try to hard incase I damage the caliper
thanks again
Old Sep 2, 2009 | 06:29 AM
Well, to me it feels like lots of resistance, but smooth. There's rubber seals around the piston, and then there's the dust boot which you have to mind (don't let it wrinkle & tear).
I normally use a 1-inch putty knife as a screwdriver in that big slot in the piston face. It's the kind of resistance where it'll move slowly & smoothly.
Old Sep 4, 2009 | 01:52 PM
freeze101
Cheers for the reply JIM I have seen it done before with the big screwdriver/puttyknife tool but mine just feel like they are way to tight and Im scared of putting any real force behind it incase I damage the caliper and have to buy new ones mainly because I did this to my dads last year due to not doing my homework correctly if indeed they are seized is their a way to free them like spraying them and leaving it to soak or easing it out a bit more with the pedal and then trying to take it back in ? Ill try anything if you think it will help
thanks again
freeze
Old Sep 4, 2009 | 02:54 PM
I have not run into the problem you describe. I bet you'll have to dismantle the caliper. (Take out the piston, seals, & dismantle the handbrake stuff.) That requires some strange long-nose snap-ring pliers.
For a start you might disconnect the hose, pour rust-dissolver in (Kroil, Liquid-Wrench, PB-Blaster, etc.) Then if it doesn't free up, you might have to buy rebuilt calipers anyway. Any chance they've been damaged by a previous mechanic pressing them straight in with a C-clamp?
Sorry I'm not much help, but mine have always turned. Without applying much force they DO turn but very slowly.
Old Sep 4, 2009 | 03:19 PM
I've usually managed to turn them w/ a wood chisel end. I've found the intial turn or so to be very hard, at least w/ only my wrist for torque. If you have leverage w/ a ratchet-driven tool, that would be different. I don't think you can damage anything w/ wrist-only torque.
Dec 23, 2010 08:50 AM
BigRigg
Jan 25, 2009 03:25 PM
BigRigg
Jun 6, 2008 02:48 PM
karb0nk0py
Sep 16, 2007 12:03 PM
