Crank Pulley removal
Hit the nut on the crank pulley with my impact wrench, no budge. Put a breaker bar and a three foot pipe on it, almost tipped the engine and stand over. It loosens counter-clockwise, correct? I do not want to twist anything off so I end up replacing the crank. '96 Accord EX, VTEC, automatic. Thanks
RE: Crank Pulley removal
Yes, it's a normal CCW to loosen bolt. It can be hellishly tight and difficult to break loose. I've never heard of anyone twisting the bolt head off,...yet.
Lot's of posts on this subject in the forum. A search should find them. good luck |
Congrats you've found the tightest bolt on the car, as stated lots of posts about this and that thing is REALLY tight, have someone stand on the engine stand to keep it from tipping and try a bigger breaker bar, put a jack stand underneath the head of the socket wrench to support it, also, hose it down with some wd-40 or other loosening stuff a few times and let it penetrate then try it.
I've heard that 3/4" impacts with 500+ ft. lbs. can get them loose... otherwise if the motor isn't in the car you might be SOL.
1" breaker bar with an 8 foot fence post FTW!!!
ORIGINAL: sir_nasty Tony, what did we decided that crank pulley holder was called? Special Holder In Tool?? |
ORIGINAL: falkore24 1" breaker bar with an 8 foot fence post FTW!!! |
I meant the drive!!!! I've seen it in my machinist friend's truck!!!
Heat the bolt with a torch too.
ORIGINAL: falkore24 I meant the drive!!!! I've seen it in my machinist friend's truck!!! imjrk, if all of those suggestions don't get it off then just rent a VERY high torque impact gun and go at it... |
| All times are GMT -5. The time now is 11:20 PM. |
