Crank Pulley removal
Old Dec 13, 2007 | 11:55 AM
imjrk's Avatar
Default Crank Pulley removal
Hit the nut on the crank pulley with my impact wrench, no budge. Put a breaker bar and a three foot pipe on it, almost tipped the engine and stand over. It loosens counter-clockwise, correct? I do not want to twist anything off so I end up replacing the crank. '96 Accord EX, VTEC, automatic. Thanks
Old Dec 13, 2007 | 12:02 PM
Default RE: Crank Pulley removal
Yes, it's a normal CCW to loosen bolt. It can be hellishly tight and difficult to break loose. I've never heard of anyone twisting the bolt head off,...yet.
Lot's of posts on this subject in the forum. A search should find them.
Old Dec 13, 2007 | 12:32 PM
finch13's Avatar
I've heard that 3/4" impacts with 500+ ft. lbs. can get them loose... otherwise if the motor isn't in the car you might be SOL.
sir_nasty's Avatar
Congrats you've found the tightest bolt on the car, as stated lots of posts about this and that thing is REALLY tight, have someone stand on the engine stand to keep it from tipping and try a bigger breaker bar, put a jack stand underneath the head of the socket wrench to support it, also, hose it down with some wd-40 or other loosening stuff a few times and let it penetrate then try it.
Old Dec 13, 2007 | 12:41 PM
falkore24's Avatar
1" breaker bar with an 8 foot fence post FTW!!!
Old Dec 13, 2007 | 12:53 PM
falkore24's Avatar
ORIGINAL: sir_nasty
Tony, what did we decided that crank pulley holder was called?
Special
Holder
In
Tool??
Old Dec 13, 2007 | 01:11 PM
sir_nasty's Avatar
ORIGINAL: falkore24
Did you mean 1'? I haven't seen a 1 inch breaker bar before *L* That looks like a mistake I'd do...
Old Dec 13, 2007 | 01:26 PM
falkore24's Avatar
I meant the drive!!!! I've seen it in my machinist friend's truck!!!
Old Dec 13, 2007 | 04:29 PM
00AccordLX5spd's Avatar
Registered User
Heat the bolt with a torch too.
Old Dec 13, 2007 | 04:32 PM
sir_nasty's Avatar
ORIGINAL: falkore24
ok, then I'll accept that one....
imjrk, if all of those suggestions don't get it off then just rent a VERY high torque impact gun and go at it...
