-   -   crank seal & TB replacement costs (https://www.hondaaccordforum.com/forum/general-tech-help-7/crank-seal-tb-replacement-costs-55480/)
momonola Jun 25, 2013 07:53 AM
07 accord EX-L 108K mi. Still runs as smooth as it did at 5 mi. Dealer gave me printout showing rear crank seal and timing belt are worn and need replacing. Their quote was $2800. Just curious if that's a fair price in SE Va? Can these repairs wait a couple of months?
JimBlake Jun 25, 2013 08:16 AM
I take it this is a V-6?? Because the 4-cyl from that year doesn't have a timing belt.
The timing belt is due at about 105k miles, so YES I would do that one. The rear seal is more of a judgement. How much oil is leaking from there?
shipo Jun 25, 2013 08:26 AM
Assuming you have a V6 engine:
  • Unless your dealer can prove to you that rear seal is leaking after only 105,000 miles I'd tell him to pound sand; sounds like he's trying to fatten his bottom line at the expense of your wallet. My suggestion would be to find a different dealer.
If you have the 4-Cylinder engine:
  • Your dealer is a crook and you should, A) report him to Honda of North America and the BBB, and B) find yourself a different dealer.
momonola Jun 25, 2013 01:22 PM
Yes it's a V-6, and no oil is leaking. Interesting... Won't be the first time dealer has tried to get me. This forum has saved me a lot of money on DIY minor repairs. Thanks for the feedback.
Dr. Drivability Jun 25, 2013 04:20 PM
gotta pull the transmission for the rear seal. timing belt job with waterpump replacement and parts should only run about 700-800 bucks give or take a couple pennies...
JimBlake Jun 25, 2013 04:57 PM
If the rear seal was actually leaking, it would make a puddle of oil directly underneath the point where the transmission attaches to the engine. At the very least the underside of the engine would get oily if it's a slow leak. Lots of people tolerate slow leaks for a long time, but 2007 is kinda new for a leaky seal.
You are the one person who can look for oil underneath your car.
