Crossed battery terminals on jump start
Ok, let me just get this out of the way, it was dark, I was in a rush, I was doing a jump start, and I was an idiot and I crossed the positive and negative on the battery. Yes stupid me. Now I get to fix my mistake....
Battery is dead, and the battery fuse is also blown. 04 Accord EX 6 cylinder with about 225k miles. Clearly, I need to get a new battery fuse. Beyond that, before I buy a new battery, can I just attach jumper cables to another car and see if my accord will go into accessory? I'm concerned that the ECU may be blown or other damage... and if it's a big deal then this car is off to the junkyard. Not that replacing the ECU is too big of a job if I need to do it... but my point is I don't know what could be wrong.
So right now 1. Replace battery fuse (I need to get a new one) 2. Test to see if car will go into accessory 3. Get new battery if does.
Is that a solid plan? Or should I do something else?
Good plan with a different battery. Hopefully you can get to accessory mode and the fuse(s) did their job and protected your electronic components.
Once main fuse is replaced and battery jumpered, use a test light to check the other fuses. You could have blown other fuses downstream of the main battery fuse before it blew.
I really lucked out - the battery fuse did its job, blew immediately and protected everything else. So no other consequences. But let this be a warning to anyone else, no matter how rushed you are don't cross polarity on the battery, take an extra 30 seconds to verify before hooking up those cables!
jddavis16
DIY Answers.
Oct 28, 2009 12:33 PM
