cruise control
my criuse control isnt working.. i checked all the conections the fuses and the sensors on the clutch and brake. I havent checked the switch on the steeringwheel beacuse I dont know how to get it off. what are some more things that I should troubleshoot for. and how do I do it. thanks
so all the fuses are good, did you chk the connection by the accumulator?? under hood left frt area ??
answering lightshows questions, it would shine more lite into the matter ,,
o yea! i forgot to mention that the both lights light up. the one on the button and the one by the gauges. but when I press it and set it nothing happens. the car just slows down when i let off the gas. I checked all the connections under the hood front area and there fine.
ok then yea it sounds like the system is working good. i bet its the accumulator then too. if you look under the hood its on the right side, its round its on a stand and it has a wire leading to the throttle body. make sure that all vacuum lines and the electrical plug are secure...the diaphram inside that unit may be bad or there may be a hose thats leaking vacuum. or maybe even the cable that goes from the accumulator to the throttle body may be broken.
