Cruise control
Old Mar 10, 2012 | 01:27 PM
tbrough's Avatar
Default Cruise control
Whenever I press the master button, it lights up as it should, yet the unit will never engage when I press Set at highway speed. Any suggestions?
Old Mar 10, 2012 | 04:07 PM
Is the CEL on, or any stored codes....tach, speedo, odo and trip odo are all working.
Factory set up....no swaps of engine or trans.
Old Mar 10, 2012 | 04:14 PM
Are your brake lights working properly?
Old Mar 10, 2012 | 05:24 PM
crispin's Avatar
Is the CC cable hooked up to the throttle.
Old Mar 10, 2012 | 08:12 PM
tbrough's Avatar
poorman212, everything is working properly, is factory and no CEL.
PAhonda, all brake lights are working propely, ALTHOUGH the brake lamp indicator is on.
crispin, I'll have to learn up on that and check it out.
Old Mar 11, 2012 | 08:36 AM
I'd start with testing the clutch switch....there are two.
Old Mar 11, 2012 | 09:38 PM
tbrough's Avatar
I know one switch is near/part of the clutch pedal; where is the other switch located?
Old Mar 12, 2012 | 10:53 PM
tbrough's Avatar
Issue resolved! The grommet in the clutch pedal had rotted away and was missing, therefore causing the clutch switch to not depress and do its job by not allowing cruise engagement. Had a similar issue with the brake pedal grommet a few years back, and my brake lamps stayed on. Can't believe it just hit me to check for that in this case. Temporary fix of a piece of old credit card and electrical tape in place until I can get the part.
Old Mar 13, 2012 | 06:48 PM
Kind of why I was thinking of starting with the switch
Glad you got it and thank you for letting us know what you found.....too many time we never know.
deckerhonda
Jan 24, 2006 09:12 PM
wskipper
Nov 19, 2005 03:49 PM
SeminoleB
Nov 9, 2005 01:52 AM
rabbit
May 3, 2005 01:28 AM
austinbc1
May 2, 2005 08:16 PM
