Crunching noise when drving over bumps
Old Dec 1, 2006 | 12:51 AM
manual123's Avatar
Default Crunching noise when drving over bumps
on my 97 4dr accord, it seems like it just started happening. i drive over deep bumps or small bumps at about 20 mph and i hear a crunch sound like its bottoming out or as if the wheels are touching the wheel wells as it hits the bump. stock suspension and wheels. any ideas????? please help
Old Dec 1, 2006 | 01:14 AM
deserthonda's Avatar
Default RE: Crunching noise when drving over bumps
lube the inner sway bar bushings............remove the 2 ,,12mm bolts for the holder, remove the bushings and lube the INSIDE PART ONLY where it rides on the bar,, do not put grease on the outside of the bushing,, put it together and see if that helps
Old Dec 1, 2006 | 01:35 AM
manual123's Avatar
thanks, ill have to try that.
Old Dec 1, 2006 | 01:36 AM
hondadude's Avatar
Click up this link;
swaybar bushings
Old Dec 1, 2006 | 01:46 AM
ORIGINAL: hondadude
Click up this link;
swaybar bushings
ooops i forgot to mention to him that we have the How to ou our DIY section that you wrote up
dculp001
Jan 7, 2015 07:39 PM
deathraypa
Feb 29, 2012 12:16 PM
maro
Jan 7, 2008 01:06 PM
thunder_x
Dec 10, 2007 10:24 AM
deserthonda
Sep 5, 2006 02:57 AM
