Crusie control questions
Old Apr 7, 2017 | 09:47 AM
'89 Accord LX's Avatar
Default Crusie control questions
So ive been wanting to ask this for a while now, the cruise control in my '89 accord doesn't work. The light in the dash won't come on either and when we first got the car it worked for about a week then never worked again. I've tried replacing the push button for it but no luck. Would anyone like to share their opinion?
Old Apr 9, 2017 | 06:32 AM
Does the "master" switch light up?
Old Apr 11, 2017 | 03:30 PM
It used to light up when we bought it many years ago but when it quit working i replaced the master switch and it still doesn't come on
Old Apr 12, 2017 | 07:43 PM
I'd start testing there, yes these things are old and the "light" could be burnt so we need to see of that is the issue or something else.
Old Apr 14, 2017 | 03:23 PM
None of the cruise control lights come on. It might be more than a bulb
Old Apr 15, 2017 | 08:19 AM
Is the #4 under dash fuse good?
Pull the coin holder, bottom row of fuses, count from the left to the right. 4th fuse should be a 7.5 amp.
Old Apr 22, 2017 | 03:59 PM
I checked the fuse and it's still okay. Is there anything else that could be faulty?
Old Apr 23, 2017 | 06:44 AM
Nothing I would call "simple", from here you would need to get out the old volt meter and start tracing wires to figure out what is going on.
Old Apr 25, 2017 | 10:02 PM
Do you have any idea where the control unit is for the cruise control? I think that may be the issue
Old Apr 26, 2017 | 01:12 PM
The 90's accords have it under the dash on the driver's side. A shop manual will help a lot.
The common diy thread on top of the gen tech help section has an online shop manual link
Here is the link. https://www.hondaaccordforum.com/for...-manuals-4597/
The hondahookup site has an 89 non-US shop manual you can download as a pdf. That should help with locating items. The wiring diagrams may or may not be exactly the same, but should help with testing.
I'd recommend testing the inputs to the cruise control module before condemning the module itself.
