d4 light flashing
Old Apr 16, 2008 | 10:18 AM
begintherev
Default d4 light flashing
hello. new accord owner and user here.
i just recently purchased a 1996 accord and now the d4 light is flashing. I have read there is a way to get a code from the flashes. Can someone please step me through this to help me figure out the problem.
The light only flashes sometimes, but when it does the transmission wont shift in D4. I can manually shift it through 1, 2, and d3. But it will not shift on it's own.
Any advice would be greatly appreciated!
Old Apr 16, 2008 | 11:19 AM
Default RE: d4 light flashing
Follow the instructions on how to check cel on this link http://www.dhost.info/accordinfo/
The only difference is that you count the D4 flashes instead of the CEL flashes.
Old Apr 16, 2008 | 11:39 AM
begintherev
okay. i just did that and i got 7 short blinks from the d4 light.
7 shows up as throttle position censor... doesn't make sense for the d4 light.
EDIT:
actually maybe it was 7 long. This gives me:
70 Automatic Transmission malfunction with the automatic transmission controls
what does this mean?
Old Apr 16, 2008 | 02:42 PM
That list of codes are for the ECU when you count the check engine light. There is a different list of codes for the TCU.
Code 7 means there is a problem with the shift solenoid valve A. If you download the tranny pdf on that page I referenced above, you can find the list of codes on 14-50.
A quick test is to look at the end of the code 4 tree and test the resistance on the solenoid. If it is out of spec, the solenoid is likely bad. If it is in spec, you might just have to remove the solenoid and clean it (with something like throttle body cleaner) and the screen due to buildup over time.
Old Apr 16, 2008 | 03:21 PM
begintherev
well i just checked the solenoids and it seems that one of the connections was pulled out alittle. Hopefully this is the cause! i dont see why it wouldn't be.
It's still showing up 7 blinks when i check it, but maybe it's cause it's still in the memory.
hopefully this fixed it. simple stuff.
Old Apr 16, 2008 | 04:34 PM
You can erase the ecu memory by pulling the 7.5 amp radio(backup) fuse in engine bay fuse box for a minute. Just have your radio code handy to reenter into the stereo. If the code comes back, then you will know for sure that it wasn't a faulty connection.
Old Apr 16, 2008 | 04:50 PM
deserthonda's Avatar
if that did not fix it let us know,, there is a easy quick test to test the solenoids to make sure that they are ok
Old Apr 17, 2008 | 12:20 AM
begintherev
thanks! i appreciate all the help!
jwk8199
Sep 23, 2010 03:47 PM
mbisenius
Sep 12, 2006 11:20 PM
jrcastro
Jun 25, 2006 12:03 PM
davidk
Sep 16, 2005 01:55 AM
moranger
May 11, 2005 10:23 PM
