Dead starter?
Old May 18, 2012 | 01:19 PM
jackfast's Avatar
Question Dead starter?
Without warning, I turned the key and nothing happened. No clicks, no sound at all. Battery is fully charged, electric windows working etc... Pushed the car and bump started first try. Is my starter dead? Could it be something else? Something cheaper? Thanks in advance.
Old May 18, 2012 | 06:30 PM
jackfast's Avatar
Bumping for some help, please.
Old May 18, 2012 | 06:50 PM
crispin's Avatar
Have you tried searching for the answer yet?
This is a problem that has been discussed many many times already.
Old May 18, 2012 | 06:51 PM
crispin's Avatar
Old May 19, 2012 | 09:22 AM
Could be....got a volt meter or test light? If so have a helper try to start the car while you check for voltage on the "small wire" to the starter......If you have voltage, then I would pull the starter and have it tested.
If you do not have voltage there, let us know as there are some more tests that will need to be done.
Old May 19, 2012 | 11:55 AM
Caveman test...
While someone holds the key in the START position, hit the starter with a broom handle or a wrench or something. If that makes it work, you need new brushes in the starter motor, or new contacts in the solenoil. Or get a new/rebuilt starter.
Old May 23, 2012 | 07:23 AM
jackfast's Avatar
Hitting the starter didnt work. I will pull it out and have it tested. I appreciate your help. Thanks.
Old May 23, 2012 | 05:47 PM
Are you getting voltage to it?
Old May 24, 2012 | 06:36 AM
Yeah, when I suggested the caveman test, that was in addition to the other testing.
matttv
Aug 12, 2013 03:50 PM
Lenno
Jan 29, 2012 07:45 PM
ohill1981
Jun 16, 2011 11:48 PM
ACCORDingly
Mar 22, 2005 02:19 AM
2pwrful
Mar 14, 2005 04:22 PM
